Aller au contenu principal
iPod 5th Generation (Video) Front Faceplate Replacement
appealingapple
appealingapple et un autre contributeur
Dernière mise à jour le November 15, 2024
5 - 15 minutes
Facile
Tutoriel réalisé par la communauté
If your iPod's front faceplate is cracked, scratched, damaged, or just boring, this guide will teach you how to replace the front faceplate of your iPod.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. iPod 5th Generation (Video) Front Faceplate Replacement, Open your iPod.: étape 1, image 1 de 1
    • Take caution while opening your iPod, making sure not to rip any ribbon cables.
    • You can use things such as a guitar pick or spudger to pry open the iPod.
  2. iPod 5th Generation (Video) Front Faceplate Replacement, Unplug the iPod's battery ribbon cable: étape 2, image 1 de 1
    • Gently unplug the battery ribbon cable from the iPod and lift up the back shell.
    • Make sure the iPod looks like the image shown.
  3. iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: étape 3, image 1 de 2 iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: étape 3, image 2 de 2
    • Using a spudger or pick, gently pry the frontplate off of the iPod's frame that holds internals such as the screen, motherboard, etc.
    • Your iPod should look like the second image when this step is completed.
  4. iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: étape 4, image 1 de 2 iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: étape 4, image 2 de 2
    • First, install the middle button that came with your new frontplate by lifting up the click wheel and simply clicking the center button into place.
    • Then, install the frontplate by just aligning the frontplate with the iPod frame and pressing it down into place until all the clips click together.
  5. iPod 5th Generation (Video) Front Faceplate Replacement, Plug the battery ribbon cable back in: étape 5, image 1 de 1
    • Before closing the iPod, make sure you reconnect the battery ribbon cable.
    • Be careful not to rip it!
  6. iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: étape 6, image 1 de 2 iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: étape 6, image 2 de 2
    • Once you've completed everything and closed your iPod, try and turn it on by pressing any button on the click wheel. If it turns on and everything works without issue, than you've successfully completed this guide!
    • But, if something doesn't work after replacing it, such as there being no sound or the screen is not displaying things correctly, reopen the iPod and examine the ribbon cables and capacitors to make sure none are missing or ripped.
3 autres ont terminé cette réparation.
appealingapple
Membre depuis le 03/26/23
217 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 57
30 derniers jours : 275
Total : 2,154
