Aller au contenu principal
iPod Nano 6th Generation Front Panel Assembly Replacement
Andrew Bookholt
Andrew Bookholt et 7 autres contributeurs
Dernière mise à jour le September 21, 2024
35 minutes - 1 heure
Modérée
Use this guide to replace your Nano's front panel assembly. A new front panel assembly will provide a new front glass panel, digitizer, and LCD. The LCD is non-separable from the digitizer.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. iPod Nano 6th Generation Front Panel Assembly Replacement, Front Panel Assembly: étape 1, image 1 de 1
    • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
    • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
  2. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 2, image 1 de 1
    • While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
    • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
    • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
    • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
  3. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 3, image 1 de 2 iPod Nano 6th Generation Front Panel Assembly Replacement: étape 3, image 2 de 2
    • Lift the front panel assembly from the headphone jack side of the Nano.
    • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
    • The front panel assembly is still attached to the Nano by two cables.
  4. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 4, image 1 de 1
    • Lay the front panel assembly next to the Nano.
    • Remove the following two screws:
    • One 2.3 mm Phillips screw
    • One 2.6 mm shouldered Phillips screw
  5. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 5, image 1 de 2 iPod Nano 6th Generation Front Panel Assembly Replacement: étape 5, image 2 de 2
    • Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
    • Remove the steel shield from the Nano.
  6. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 6, image 1 de 2 iPod Nano 6th Generation Front Panel Assembly Replacement: étape 6, image 2 de 2
    • Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
  7. iPod Nano 6th Generation Front Panel Assembly Replacement: étape 7, image 1 de 1
    • Remove the front panel assembly, minding its two cables that may get caught.
    • To reassemble, you can use the double-sided tape found here.
120 autres ont terminé cette réparation.
10 commentaires
Don't forget to include in your repair the adhesive to hold the new screen on. It does not come with the new display. I as unable to find it at iFixit's site but was able to get it here for $10 incl p&p: http://www.badgizmorepair.com/product/ip...
By the time I paid for the screen, opening tool and glue it turned out to be more economical and less hassle to take it to the Apple store (albeit less satisfying than doing it yourself). I suggest you forego the opening tool if you have a good flat blade jewelers screwdriver. A fine temporary fix for not having the correct screen glue is a piece of packing tape. It leaves the iPod open to the elements though, so I highly recommend the correct glue in order to avoid water leaking in around the edge of the screen.
You will also need a very small jewellers or electronics screwdriver for the two screws. I just managed it with an oversized flathead driver.
dmcgleenan - Réponse
Hi, i already unmount the display, but i need the adhesive strips for paste the ne one. The link you suggested it's down, is it possible to have a new one where i can find this adhesive?
Thanks
quentin23 - Réponse
Its diffucult to place the display data cable when reverse step 3. Any tips?
Akela66 - Réponse
i had bought these part and succeeded in repair my drown ipod using these guides (luckily only the lcd that didnt work). and it work nicely. thanks
bubba12250 - Réponse
Thanks for the guide. Very useful and easy to follow.
Had some issues with getting the screen off initially, but that was due to the glass along the headphone jack side being cracked into several small little shards (hence the reason for following the guide ;)
Used a replacement screen (incl. toolkit and replacement precut adhesive) that I purchased from ebay for around US$10 (free shipping).
Jared Yates - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 53
30 derniers jours : 223
Total : 114,751
