Aller au contenu principal
iRobot Roomba 770 Main Wheels Replacement
Angelique Bonilla
Angelique Bonilla et un autre contributeur
Dernière mise à jour le December 5, 2016
4 minutes
Modérée
These wheels control the main movement of the device. Since it is one of the main parts used, the tires of the wheel may get worn, debris may get caught inside, or the wheel may just need to be replaced from overuse.
Ce dont vous avez besoin
  1. iRobot Roomba 770 Main Wheels Replacement, Battery: étape 1, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement, Battery: étape 1, image 2 de 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Main Wheels Replacement: étape 2, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement: étape 2, image 2 de 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Main Wheels Replacement, Side Brush Motor: étape 3, image 1 de 1
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Main Wheels Replacement: étape 4, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement: étape 4, image 2 de 2
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Main Wheels Replacement: étape 5, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement: étape 5, image 2 de 2
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
  6. iRobot Roomba 770 Main Wheels Replacement, Main Wheels: étape 6, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement, Main Wheels: étape 6, image 2 de 2
    • Locate the three 15.5 mm screws surrounding each wheel. Use a J1 Philips screw driver to remove these.
    • The screw towards the center for each wheel may be hard to locate and may seem inaccessible. The head of your screw is long enough to reach it.
    • Use your J1 Philips screwdriver to remove these screws.
  7. iRobot Roomba 770 Main Wheels Replacement: étape 7, image 1 de 2 iRobot Roomba 770 Main Wheels Replacement: étape 7, image 2 de 2
    • Pull up on the wheels to remove them from the device.
4 autres ont terminé cette réparation.
Angelique Bonilla
Membre depuis le 10/06/16
251 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-3, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 membres
5 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 29
Total : 3,059
