Aller au contenu principal
iRobot Roomba 880 Battery Replacement
Frances Belcher
Frances Belcher et 2 autres contributeurs
Dernière mise à jour le September 10, 2024
10 minutes
Facile
Use this guide if the battery of your Roomba 880 has stopped functioning, or is not working at complete capacity. This could be due to a faulty or damaged battery, overuse or exposure to heat and water. The battery is fairly easy to replace so let's tackle this together.
Ce dont vous avez besoin
  1. iRobot Roomba 880 Battery Replacement, Battery: étape 1, image 1 de 2 iRobot Roomba 880 Battery Replacement, Battery: étape 1, image 2 de 2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: étape 2, image 1 de 1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: étape 3, image 1 de 2 iRobot Roomba 880 Battery Replacement: étape 3, image 2 de 2
    • Remove the battery using the green tabs on either side of the battery.
Frances Belcher
Membre depuis le 04/18/17
420 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G4, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 membres
10 tutoriels rédigés
2 commentaires
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - Réponse
Not a very useful comment Nathan - the clue is in the title of the article. If someone wants to replace the battery in their smoke alarm.... it is kinda implicit that 'replacing it' doesn't mean taking the old one out and putting the same one back in.
Crazy cat lady -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 49
Total : 4,979
