Aller au contenu principal
Remplacement de la caméra du HTC myTouch 3G
Anglais
Français
Traduction de l’étape 1
Étape 1
HTC myTouch 3G Camera Replacement: étape 0, image 1 de 1
  • Turn the device housing the circuit boards over to the side with the mounted camera.
  • Remove the three 3 mm Phillips head screws located on the top circuit board.
Tournez la pièce contenant les circuits imprimés sur le côté avec la caméra montée.
Retirez les trois vis cruciformes de 3 mm situées sur le circuit imprimé supérieur.
-[* black] Turn the piece housing the circuit boards over to the side with the mounted camera.
-[* red] Remove the three 3-mm Phillips head screws located on the top circuit board.
+[* black] Turn the device housing the circuit boards over to the side with the mounted camera.
+[* red] Remove the three 3 mm Phillips head screws located on the top circuit board.
