Aller au contenu principal
Sony Cyber-Shot DSC-W120 Teardown
Anglais
Français
Traduction de l’étape 9
Étape 9
Sony Cyber-Shot DSC-W120 Teardown: étape 0, image 1 de 3 Sony Cyber-Shot DSC-W120 Teardown: étape 0, image 2 de 3 Sony Cyber-Shot DSC-W120 Teardown: étape 0, image 3 de 3
  • The front bezel is attached to the camera's chassis by a number of easy to release tabs.
  • Using a spudger or plastic opening tool and starting at the top of the camera, work your way around the camera's body and release the tabs holding the front bezel to the chassis. The tabs should require almost no effort to separate.
  • The bottom of the camera is a little trickier to get apart. It is held in place by three tabs on the lens side of the camera. Using a plastic opening tool or spudger, work your way along the seam while gently lifting up on the bezel. It may take a few tries to get all of the tabs to release.
  • Once the tabs have been released, the front bezel will simply lift off the camera. The approximate locations of the tabs are indicated by the yellow boxes.
Insérez ici votre traduction
