Aller au contenu principal
Garmin Avionics Wiring Termination
Anglais
Français
Traduction de l’étape 7
Étape 7
Garmin Avionics Wiring Termination, Shielding termination: étape 0, image 1 de 2 Garmin Avionics Wiring Termination, Shielding termination: étape 0, image 2 de 2
  • Insert the environmental splice over the cut shielding block and insert the shield braid into it. The solder ring must go over both the exposed shield and the braid.
  • Insert a piece of heat shrink over the end of the wire where the shield and outer insulation is cut. This will protect the end of the wire
  • Heat the splice and heat-shrink with a heat gun. Ensure the solder flows in the splice soldering the braid to the shield.
Insérez ici votre traduction
