Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 20
Étape 20
Using two crescent wrenches, unscrew the pump rod from the remaining portion. When the joint is separated, carefully lower the riser main to the ground. When the joint is separated, carefully lower the riser main to the ground.
  • Using two crescent wrenches, unscrew the pump rod from the remaining portion.
  • When the joint is separated, carefully lower the riser main to the ground.
Insérez ici votre traduction
