Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Once the outer casings have been removed, the silver side trim should come loose from the camera. Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug. Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  • Once the outer casings have been removed, the silver side trim should come loose from the camera.
  • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
  • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
Insérez ici votre traduction
