Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 3
Étape 3
Pry Open The Router
Use a plastic opening tool between the edges of the router and gently pry the device apart.
Release the clips as you work your way around the device to avoid breaking them.
Separate the front and back case of the router.
[title] Pry Open The Router | |
- | [* black] Using a plastic opening tool, trace the edges of the router on all sides. Gently pry the device until it eventually snaps open. |
+ | [* black] Use a plastic opening tool between the edges of the router and gently pry the device apart. |
+ | [* black] Release the clips as you work your way around the device to avoid breaking them. |
+ | [* black] Separate the front and back case of the router. |
