Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Place the camera on the side opposite of the wrist strap handle.
  • Place the camera on the side opposite of the wrist strap handle.
  • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
  • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
  • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
  • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
Insérez ici votre traduction
