Aller au contenu principal
iFixit utilise des cookies pour améliorer la fonctionnalité du site, analyser le trafic et personnaliser les publicités. En utilisant notre site, vous acceptez notre utilisation des cookies et notre politique de confidentialité.
Canon PowerShot S230 Motherboard Replacement
Anglais
Français
Traduction de l’étape 2
Étape 2
Canon PowerShot S230 Motherboard Replacement: étape 0, image 1 de 3 Canon PowerShot S230 Motherboard Replacement: étape 0, image 2 de 3 Canon PowerShot S230 Motherboard Replacement: étape 0, image 3 de 3
  • The motherboard can be damaged easily and must be treated with care. Try to avoid removing ribbon cables with your fingers, since motherboards are extremely sensitive to static discharge. Use a spudger or plastic opening tool to lift any flaps or tabs or to pry connectors straight off their sockets on the motherboard.
  • Before the motherboard can be removed, several ribbon cables must be disconnected from their respective ports. A few of the ribbon cables are held in place by locking ZIF connectors, which you must release before removing the cables. Removing each ribbon cable may require a gentle tug.
  • First, release the ZIF connector securing the ribbon cable in the bottom left corner of the motherboard. To do this, insert the flat end of a spudger under the connector's dark brown flap and gently wedge the flap open.
Insérez ici votre traduction
