Aller au contenu principal
Remplacement de la batterie du Nokia 2630b
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    == Introduction ==
    Changing the battery on your phone might be necessary if your battery is no longer holding adequate charge, or is no longer charging with the proper adapter cord.
    This guide will teach users to safely remove the battery of the Nokia 2630b. It is the first step to opening the phone.
    The steps required to change the battery of a Nokia 2630b are very simple and require no tools or special skills.
    '''Things to remember:'''
    * Always power down the phone prior to removing the battery.
    * Replace the battery with the manufacturer suggested battery to avoid damage to the phone.
    Follow the steps below to walk you through the replacement of the battery on your Nokia 2630b.
      Étapes du tutoriel
      Étape 1
      Appuyez sur les boutons de déverrouillage situés de chaque côté du couvercle de la batterie
      Étape 2
      Retirez délicatement la batterie du téléphone avec les doigts
