Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 12
Étape 12
Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable. Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing. Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
  • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
  • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
  • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
  • Both ribbon cables should be removed after this step.
Insérez ici votre traduction
