Aller au contenu principal
Solis 837 Blender Repair
Anglais
Français
Traduction de l’étape 6
Étape 6
Solis 837 Blender  Repair, finish and reassemble: étape 0, image 1 de 3 Solis 837 Blender  Repair, finish and reassemble: étape 0, image 2 de 3 Solis 837 Blender  Repair, finish and reassemble: étape 0, image 3 de 3
  • OK, the bearing is clean. I took some oil to lubricate the bearing.
  • Now take the small washer or replace it with a new one to cover te balls from the rubber "tire" encapsulating the bearing.
  • Take your rubber "tire" and encapsulate the bearing with it. I turned the rubber bit and cut of the fraying bits from it, preventing it to get stuck in between the balls.
  • Now put everything back together in the right order. Take note that you don't tighten the bolt to much, but good enough to tighten the knifes. Test if the bowl is waterproof with some water. If the bolt is tighten to much, the gear will be pressed against the fitting, and the rubber will be burned when rotating at high speed!
Insérez ici votre traduction
