Aller au contenu principal
Canon PowerShot SX530 HS Back Panel Assembly
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Canon PowerShot SX530 HS Back Panel Assembly: étape 0, image 1 de 2 Canon PowerShot SX530 HS Back Panel Assembly: étape 0, image 2 de 2
  • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
  • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
  • Use the Phillips PH000 to remove the 4mm screw near the USB port.
  • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
Insérez ici votre traduction
