Traduction de l’étape 4
Étape 4
The battery on the iPod Touch is attached via solder pads.
Heat the solder of the solder pads individually and use your metal spudger to pry them from the logic board.
When soldering, work from one side of the ribbon cable. Heat the side while using the spudger to gently lift the ribbon cable from the board. Repeat this process for the other two pads.
