Aller au contenu principal
Let's assume you have removed the screen from the device in order to replace wiring or the webcam.
Ce dont vous avez besoin
Outils
Afficher plus…
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Lenovo ThinkPad X1 Yoga, utilisez notre manuel de réparation.
  1. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: étape 1, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: étape 1, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Introduction: étape 1, image 3 de 3
    • Here we have the screen as just removed from our Thinkpad.
    • In the lower corners you will find two rubber caps with hidden screws.
    • Remove the caps and unscrew the first screw.
  2. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: étape 2, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: étape 2, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Display screws: étape 2, image 3 de 3
    • You have to remove the screws on the right and left side to proceed.
  3. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: étape 3, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: étape 3, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Screen cover: étape 3, image 3 de 3
    • The screws secured this rubbery, bendy cover which is removed easily by using your fingernails or a spudger.
    • When you have removed the cover store it away somewhere safe.
    • Remove the two PH1 screws marked with red circles.
  4. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: étape 4, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: étape 4, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Hinges and wiring: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Flip the display on the side. This way it is easier to pull out the plastic caps holding the display wires in place.
    • Use some tweezers to lever out the plastic cap and store it somewhere safe.
    • Gently pull out the cables from the hinge.
  5. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: étape 5, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: étape 5, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Right display hinge: étape 5, image 3 de 3
    • To the right you'll have to repeat the steps.
    • Free the cables from their prison in the hinge.
  6. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Rubber frame: étape 6, image 1 de 2 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Rubber frame: étape 6, image 2 de 2
    • The screen is secured by a rubber frame which is glued onto the display cover.
    • Use a guitar pick or a spuder to lift it off. In my case the glue was not really strong and required no heat.
  7. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: étape 7, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: étape 7, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Flex connector and removal: étape 7, image 3 de 3
    • One flex connector is reachable for us. Lift up the brass clip.
    • With the screws removed and the clip detached the display is now free
    • Be careful not to rip the other flex connector, we have to detach in the next steps.
  8. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: étape 8, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: étape 8, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnecting the display: étape 8, image 3 de 3
    • Pull the display up about an inch just so that you can detach the flex cables with the levers / clips.
  9. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: étape 9, image 1 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: étape 9, image 2 de 3 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Disconnect pt.2: étape 9, image 3 de 3
    • With all reachable connectors detached you can now lift up the screen from the cover but we're not quite there yet.
    • Flip over the screen like seen in the second picture.
    • Detach the last connector between cover and screen.
  10. Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Done!: étape 10, image 1 de 2 Lenovo ThinkPad X1 Yoga Display Assembly Teardown, Done!: étape 10, image 2 de 2
    • With the last connector removed you're done!
    • You could now replace the screen or continue the disassambly.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 24
30 derniers jours : 68
Total : 2,523
