Aller au contenu principal
This is complete Samsung Galaxy Note 4 teardown.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Tweezers
  • Phillips #000 Screwdriver
Afficher plus…
Vidéo d'introduction
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Galaxy Note 4, utilisez notre manuel de réparation.
  1. Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: étape 1, image 1 de 2 Samsung Galaxy Note 4 Teardown, Samsung Galaxy Note 4 Teardown: étape 1, image 2 de 2
    • Remove the back cover. It comes off easily.
  2. Samsung Galaxy Note 4 Teardown: étape 2, image 1 de 2 Samsung Galaxy Note 4 Teardown: étape 2, image 2 de 2
    • Remove battery, SIM card.
    • Don't forget the S Pen.
  3. Samsung Galaxy Note 4 Teardown: étape 3, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 3, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 3, image 3 de 3
    • Remove the 16 screws all together on the middle housing. That is a lot of screws.
  4. Samsung Galaxy Note 4 Teardown: étape 4, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 4, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 4, image 3 de 3
    • Cut the adhesive sticker between the screen and the middle housing. It will be easier if you apply low heat degree less than 85℃. Be careful to avoid breaking touch panel.
    • Carefully flip the housing over and loosen the hidden tabs around the battery slot.
    • Loosen the middle housing and then push the front assembly--this may take a little extra effort.
  5. Samsung Galaxy Note 4 Teardown: étape 5, image 1 de 1
    • Separate front assembly from middle housing successfully.
    • The whole front assembly comes with motherboard, USB board, cameras, LCD screen and some other small components.
    • The back housing comes with power & volume button, headphone jack and loudspeaker. And except loudspeaker, other parts are easy to remove.
  6. Samsung Galaxy Note 4 Teardown: étape 6, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 6, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 6, image 3 de 3
    • Get the flex free from the adhesive underneath and remove headphone jack naturally.
  7. Samsung Galaxy Note 4 Teardown: étape 7, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 7, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 7, image 3 de 3
    • Unlike the Galaxy S5, the Note 4 power and volume buttons are easy to remove.
  8. Samsung Galaxy Note 4 Teardown: étape 8, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 8, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 8, image 3 de 3
    • Cut the adhesive between LCD screen and mid plate carefully. Especially care about the position of the flex very much.
    • The adhesive is in the red scale, it's strong and we had damaged the foil film on the back of the screen when cut the adhesive. Heat with a low degree will make easier.
    • Release the connectors from motherboard. The right one is S Pen sensor film connector and the left one is LCD screen connector.
    • You also can see the soft keys on the bottom side. So be careful when cut the adhesive, don't hurt that part.
    • At last, remove LCD screen assembly carefully.
  9. Samsung Galaxy Note 4 Teardown: étape 9, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 9, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 9, image 3 de 3
    • Release navigation button flex connector ,get it free from the adhesive on the mid-plate and remove it.
  10. Samsung Galaxy Note 4 Teardown: étape 10, image 1 de 2 Samsung Galaxy Note 4 Teardown: étape 10, image 2 de 2
    • Remove 2 pcs of signal flexes. And maybe different versions Galaxy Note 4 comes with different numbers of signal flexes. Possibly one or two.
  11. Samsung Galaxy Note 4 Teardown: étape 11, image 1 de 2 Samsung Galaxy Note 4 Teardown: étape 11, image 2 de 2
    • Twist off two screws securing motherboard and USB board at first.
    • Don't forget to release the earpiece speaker connector.
  12. Samsung Galaxy Note 4 Teardown: étape 12, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 12, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 12, image 3 de 3
    • Pry up the motherboard.
    • Release USB charging board from motherboard.
    • Finally, remove Galaxy Note 4 motherboard.
  13. Samsung Galaxy Note 4 Teardown: étape 13, image 1 de 2 Samsung Galaxy Note 4 Teardown: étape 13, image 2 de 2
    • By the way, remove rear camera from motherboard. Release the connector and can take the camera away easily.
  14. Samsung Galaxy Note 4 Teardown: étape 14, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 14, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 14, image 3 de 3
    • Now, it's the turn of front camera assembly.
    • Release the connector at first, and then get free the two clasps, at last remove the front camera with sensors together.
  15. Samsung Galaxy Note 4 Teardown: étape 15, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 15, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 15, image 3 de 3
    • Get recent apps button and back button free from the adhesive on the mid plate.
    • Pry up the USB charging board and remove it.
  16. Samsung Galaxy Note 4 Teardown: étape 16, image 1 de 2 Samsung Galaxy Note 4 Teardown: étape 16, image 2 de 2
    • Pry up and remove earpiece speaker.
  17. Samsung Galaxy Note 4 Teardown: étape 17, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 17, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 17, image 3 de 3
    • Vibrator comes with power button flex together.
  18. Samsung Galaxy Note 4 Teardown: étape 18, image 1 de 3 Samsung Galaxy Note 4 Teardown: étape 18, image 2 de 3 Samsung Galaxy Note 4 Teardown: étape 18, image 3 de 3
    • Remove volume button flex.
  19. Samsung Galaxy Note 4 Teardown: étape 19, image 1 de 1
    • Done.
Sophia
Membre depuis le 03/25/14
43 861 Réputation
62 tutoriels rédigés
26 commentaires
horrible.
what happened Samsung? Why suddenly screw with repairers?
pseudonymous - Réponse
Samsung has gone from the most repairable telephones to one of the worst.
I'd also like to note @ Step 8. Be VERY careful of the menu respectively the return key flexes located at the bottom of the screen while seperating the LCD from the chassi. They tend to "follow with" the sceren and break.
If they do break you'll have to replace the entire charging contact in order to restore them to full function.
Alexander - Réponse
Thnx For The Important Tip
iABDOzz Mustafa -
Can you fit interior of note 3 inside chasis of note 4
Eddy Kelemis - Réponse
ever make any progress with getting that note 3 to fit in the note 4 chassis?
wqhj studios -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 81
Total : 165,571
