Introduction
Passez à l'étape 1Teardown showing all the guts of an old Samsung T139 flip phone.
Ce dont vous avez besoin
Start by removing the back of the phone. Once that is done you will find 4 Phillips 00 screws two on the top left and right and two on the bottom left and right
Take out the battery
You will see 4 phillips 00 screws, two on the top left and right and two on the bottom left and right. Remove them.
Outil utilisé dans cette étape :Jimmy$7.95
Take the Jimmy and go around the sides of the phone until the outer border comes off.
Outil utilisé dans cette étape :Spudger$2.99
Push gently on the side of the screen cable with a Spudger to release
Then remove the logic board.
Outil utilisé dans cette étape :Tweezers$4.99
Take the keyboard out by pulling gently on the side with some tweezers
Remove the two black screw covers on the bottom of the screen
Remove the two screws that are revealed
Take a Jimmy and go around it until the front case (the one with the smaller screen) comes off.
After you are done with step six the phone should look like this
Take a Spudger and push up on the little black bar at the top end of the screen to logic board cable
Take a Spudger and push up the little red bar over the camera cable.
Pull the cable out and remove the camera.
Take a pair of tweezers and lift up to remove the screen.
Congrats! Your done. Let's take a look at what we have.
Outer cases
Screens
Logic board
A camera
Some button covers
A battery
A keypad cover
