Aller au contenu principal
Ce dont vous avez besoin
Outils
Afficher plus…
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Toshiba Satellite M45, utilisez notre manuel de réparation.
  1. Toshiba Satellite M45 Teardown, Battery: étape 1, image 1 de 3 Toshiba Satellite M45 Teardown, Battery: étape 1, image 2 de 3 Toshiba Satellite M45 Teardown, Battery: étape 1, image 3 de 3
    • Make sure device is off and power supply is disconnected.
    • Flip the laptop to the bottom side.
    • Locate and slide the two battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Toshiba Satellite M45 Teardown, Optical Drive: étape 2, image 1 de 3 Toshiba Satellite M45 Teardown, Optical Drive: étape 2, image 2 de 3 Toshiba Satellite M45 Teardown, Optical Drive: étape 2, image 3 de 3
    • Use the #1 Phillips head screwdriver remove the Optical Drive screw.
    • Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
    • Use your hands to pull the rest of the Optical Drive out.
  3. Toshiba Satellite M45 Teardown, RAM: étape 3, image 1 de 3 Toshiba Satellite M45 Teardown, RAM: étape 3, image 2 de 3 Toshiba Satellite M45 Teardown, RAM: étape 3, image 3 de 3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
  4. Toshiba Satellite M45 Teardown, Hard Drive: étape 4, image 1 de 3 Toshiba Satellite M45 Teardown, Hard Drive: étape 4, image 2 de 3 Toshiba Satellite M45 Teardown, Hard Drive: étape 4, image 3 de 3
    • Use the #1 Phillips head screwdriver as to remove the hard drive screw.
    • Use the blue iFixit Opening Tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Toshiba Satellite M45 Teardown, Wi-Fi Card: étape 5, image 1 de 3 Toshiba Satellite M45 Teardown, Wi-Fi Card: étape 5, image 2 de 3 Toshiba Satellite M45 Teardown, Wi-Fi Card: étape 5, image 3 de 3
    • Use the #1 Phillips head screwdriver to unscrew the panel.
    • Disconnect the black and white wires.
    • Push on the tabs to disconnect the Wi-Fi card.
    • Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
  6. Toshiba Satellite M45 Teardown, Display: étape 6, image 1 de 1
    • Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
    • Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
    • Flip the laptop back over and open the display.
  7. Toshiba Satellite M45 Teardown: étape 7, image 1 de 3 Toshiba Satellite M45 Teardown: étape 7, image 2 de 3 Toshiba Satellite M45 Teardown: étape 7, image 3 de 3
    • Remove the two Phillips #1 screws securing the display hinges.
    • It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four Phillips #1 screws on the back of the laptop.
  8. Toshiba Satellite M45 Teardown: étape 8, image 1 de 1
    • Gently pull up on the display's video connector to remove it.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
  9. Toshiba Satellite M45 Teardown, Keyboard: étape 9, image 1 de 3 Toshiba Satellite M45 Teardown, Keyboard: étape 9, image 2 de 3 Toshiba Satellite M45 Teardown, Keyboard: étape 9, image 3 de 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  10. Toshiba Satellite M45 Teardown: étape 10, image 1 de 3 Toshiba Satellite M45 Teardown: étape 10, image 2 de 3 Toshiba Satellite M45 Teardown: étape 10, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  11. Toshiba Satellite M45 Teardown, Speakers: étape 11, image 1 de 3 Toshiba Satellite M45 Teardown, Speakers: étape 11, image 2 de 3 Toshiba Satellite M45 Teardown, Speakers: étape 11, image 3 de 3
    • Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
    • Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
  12. Toshiba Satellite M45 Teardown: étape 12, image 1 de 2 Toshiba Satellite M45 Teardown: étape 12, image 2 de 2
    • To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise.
    • Reverse the order after installing the new speakers.
  13. Toshiba Satellite M45 Teardown, Cooling Unit: étape 13, image 1 de 3 Toshiba Satellite M45 Teardown, Cooling Unit: étape 13, image 2 de 3 Toshiba Satellite M45 Teardown, Cooling Unit: étape 13, image 3 de 3
    • Remove the cover from the cooling unit.
  14. Toshiba Satellite M45 Teardown: étape 14, image 1 de 2 Toshiba Satellite M45 Teardown: étape 14, image 2 de 2
    • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  15. Toshiba Satellite M45 Teardown: étape 15, image 1 de 1
    • Follow the tear-down guide until you have access to the fan unit on the motherboard.
  16. Toshiba Satellite M45 Teardown: étape 16, image 1 de 3 Toshiba Satellite M45 Teardown: étape 16, image 2 de 3 Toshiba Satellite M45 Teardown: étape 16, image 3 de 3
    • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  17. Toshiba Satellite M45 Teardown, Motherboard: étape 17, image 1 de 3 Toshiba Satellite M45 Teardown, Motherboard: étape 17, image 2 de 3 Toshiba Satellite M45 Teardown, Motherboard: étape 17, image 3 de 3
    • Disconnect the video cable, then slowly and firmly pull the video cable upwards.
    • Disconnect the brown ribbon located in the middle area of the laptop.
    • Disconnect the two white ribbons located in the bottom left of the laptop.
    • Firmly pull out the two white ribbons.
  18. Toshiba Satellite M45 Teardown: étape 18, image 1 de 2 Toshiba Satellite M45 Teardown: étape 18, image 2 de 2
    • Use the Phillips #00 Screwdriver to unscrew all the screws.
    • Unscrew three additional screws through the three holes on the optical drive.
  19. Toshiba Satellite M45 Teardown: étape 19, image 1 de 3 Toshiba Satellite M45 Teardown: étape 19, image 2 de 3 Toshiba Satellite M45 Teardown: étape 19, image 3 de 3
    • Turn the laptop upside down.
    • Use the blue iFixit Opening Tool to slowly pry the case upward.
    • Remove the white ribbon
    • Make sure to completely remove the white ribbon and set it to the right side of the motherboard. and not on top of the motherboard.
  20. Toshiba Satellite M45 Teardown: étape 20, image 1 de 2 Toshiba Satellite M45 Teardown: étape 20, image 2 de 2
    • Lift up the motherboard.
    • Be careful not to rip out small components on the motherboard. Carefully remove the motherboard.
  21. Toshiba Satellite M45 Teardown, Toshiba Satellite M45 Teardown: étape 21, image 1 de 1
    • Congratulations, your computer has been completely dismantled!
    • Now, reverse the steps to reassemble.
Bobby Davis
Membre depuis le 03/11/14
154 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 4-1, Calaway Spring 2014 Membre de l'équipe UMass Dartmouth, Team 4-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S4G1
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 2,613
