AirPort Extreme Card
6 Réponses Indice de 3 |
On startup, folder with question mark and finder window appears. |
4 Réponses Indice de 3 |
Possible to Swap Logic Boards? |
8 Réponses Indice de 2 |
Why does my screen flash solid colors then displays a gray screen? |
2 Réponses Indice de 1 |
Problem re-installing new hard-drive |
Pièces
Outils
Voici quelques outils couramment utilisés pour travailler sur cet appareil. Vous ne devriez pas avoir besoin de tous les outils pour chaque procédure.
Troubleshooting
Track down a number of hardware problems using the iBook G4 14" 933 MHz-1.33 GHz Troubleshooting Guide.
Upgrades
There are a number of components in the iBook G4 14" 933 MHz-1.33 GHz can be cost effectively upgraded.
- Memory: The iBook G4 14" 933 MHz-1.33 GHz has one RAM slot. You can add up to 1 GB of memory to your computer. Browse the [/Mac-Parts/iBook-G4-14%22-1.2-GHz#0-RAM|RAM] category, or check out our easy iBook G4 14" 933 MHz-1.33 Ghz RAM installation instructions.
- Hard Drive: Browse our [/Mac-Parts/iBook-G4-14%22-1.2-GHz#0-Hard+Drives+PATA+|hard drives] and upgrade today. Oh, and with our tools and instructions, you can even install it yourself!
- Optical Drive: The 8x Super Drive allows you to read and write both CDs and DVDs. Browse our optical drive category for additional [/Mac-Parts/iBook-G4-14%22-1-GHz-128-RAM#0-Optical+Drives|optical drives]. Install your new optical drive yourself, the easy way.
Background and Identification
Use the [/info/ID-your-Mac|laptop identification system] to help you identify your machine. iBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
