Aller au contenu principal
Asus Transformer T100 Battery Replacement
Taylor Pantiga
Taylor Pantiga et 9 autres contributeurs
Dernière mise à jour le January 29, 2018
10 - 20 minutes
Modérée
A besoin de meilleures images
The battery is located inside the tablet part of the device. The plastic backing must be removed before the battery can be accessed.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Asus Transformer T100 Battery Replacement, Rear Cover: étape 1, image 1 de 2 Asus Transformer T100 Battery Replacement, Rear Cover: étape 1, image 2 de 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Battery Replacement: étape 2, image 1 de 2 Asus Transformer T100 Battery Replacement: étape 2, image 2 de 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Battery Replacement: étape 3, image 1 de 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Battery Replacement: étape 4, image 1 de 2 Asus Transformer T100 Battery Replacement: étape 4, image 2 de 2
    • Remove the rear casing.
  5. Asus Transformer T100 Battery Replacement, Battery: étape 5, image 1 de 1
    • Remove the copper tape carefully.
  6. Asus Transformer T100 Battery Replacement: étape 6, image 1 de 2 Asus Transformer T100 Battery Replacement: étape 6, image 2 de 2
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
  7. Asus Transformer T100 Battery Replacement: étape 7, image 1 de 3 Asus Transformer T100 Battery Replacement: étape 7, image 2 de 3 Asus Transformer T100 Battery Replacement: étape 7, image 3 de 3
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
  8. Asus Transformer T100 Battery Replacement: étape 8, image 1 de 2 Asus Transformer T100 Battery Replacement: étape 8, image 2 de 2
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
69 autres ont terminé cette réparation.
Taylor Pantiga
Membre depuis le 04/14/14
1 617 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-31, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 membres
6 tutoriels rédigés
22 commentaires de tutoriel
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Réponse
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes -
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Réponse
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Réponse
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 168
Total : 130,679
