Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 5a Rear Camera Replacement
Ce dont vous avez besoin
  1. Google Pixel 5a Rear Camera Replacement, Precautionary notes: étape 1, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Precautionary notes: étape 1, image 2 de 2
    • Be sure to turn off your device before you begin the repair.
    • You'll need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 5a Rear Camera Replacement, Heat the right edge of the screen: étape 2, image 1 de 1
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • Depending on the strength of your device's adhesive, you may need to reapply the iOpener multiple times in order to weaken it enough.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Demander à FixBot
  3. Google Pixel 5a Rear Camera Replacement, Bezel removal note: étape 3, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Bezel removal note: étape 3, image 2 de 2
    • To remove the screen, you'll need to insert opening picks in between the black clips that secure the bezel to the midframe.
    • Note the optimal points of entry before proceeding.
    Demander à FixBot
  4. Google Pixel 5a Rear Camera Replacement, Create a gap between the bezel and midframe: étape 4, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Create a gap between the bezel and midframe: étape 4, image 2 de 2
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force until a small gap forms between the bezel and midframe.
    Demander à FixBot
  5. Google Pixel 5a Rear Camera Replacement, Insert an opening pick: étape 5, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Insert an opening pick: étape 5, image 2 de 2
    • The bezel is connected to the midframe by a series of plastic clips which can be detached by inserting an opening pick at points all along the seam.
    • Insert the tip of an opening pick into the bezel seam about 4-5 cm from the bottom of the phone.
    Demander à FixBot
  6. Google Pixel 5a Rear Camera Replacement: étape 6, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 6, image 2 de 2
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm from the top of the phone.
    Demander à FixBot
  7. Google Pixel 5a Rear Camera Replacement: étape 7, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 7, image 2 de 2
    • Insert the tip of an opening pick into the bezel seam at the top of the phone.
    • If this step proves difficult, slide the pick along the top right corner of the phone until there is enough of a gap at the top for the opening pick.
    Demander à FixBot
  8. Google Pixel 5a Rear Camera Replacement: étape 8, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 8, image 2 de 2
    • Insert the tip of an opening pick into the bezel seam at the bottom of the phone.
    • If this step proves difficult, slide the pick along bottom right corner of the phone until there is enough of a gap at the bottom for the opening pick.
    Demander à FixBot
  9. Google Pixel 5a Rear Camera Replacement: étape 9, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 9, image 2 de 2
    • Insert the tip of an opening pick into the bezel seam on the left side of the phone, about 2 cm from the bottom of the phone.
    Demander à FixBot
  10. Google Pixel 5a Rear Camera Replacement: étape 10, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 10, image 2 de 2
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm below the front-facing camera.
    Demander à FixBot
  11. Google Pixel 5a Rear Camera Replacement: étape 11, image 1 de 3 Google Pixel 5a Rear Camera Replacement: étape 11, image 2 de 3 Google Pixel 5a Rear Camera Replacement: étape 11, image 3 de 3
    • Be sure to detach all the clips. Slice through any remaining adhesive with an opening pick.
    • Open the device from the right side like a book.
    Demander à FixBot
  12. Google Pixel 5a Rear Camera Replacement: étape 12, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $16.96
    • Use a T3 Torx driver to remove the 4.6 mm-long screw securing the screen connector bracket.
    Demander à FixBot
  13. Google Pixel 5a Rear Camera Replacement, Remove the connector bracket: étape 13, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Remove the connector bracket: étape 13, image 2 de 2
    • Use a pair of tweezers to remove the screen connector bracket.
    Demander à FixBot
  14. Google Pixel 5a Rear Camera Replacement, Remove the screen: étape 14, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Remove the screen: étape 14, image 2 de 2
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Demander à FixBot
  15. Google Pixel 5a Rear Camera Replacement, Screen information: étape 15, image 1 de 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Demander à FixBot
  16. Google Pixel 5a Rear Camera Replacement: étape 16, image 1 de 1
    • Remove the screen from the phone.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • Remember to reinstall the screen connector bracket.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Demander à FixBot
  17. Google Pixel 5a Rear Camera Replacement, Remove the screws: étape 17, image 1 de 1
    • Use a T3 Torx driver to remove six of the screws securing the midframe to the motherboard:
    • Four 4.6 mm screws
    • One 4.0 mm screw
    • One 2.0 mm screw
    • Since a few of these screws have different lengths, keep track of each screw and be sure to reinstall them in their proper places.
    Demander à FixBot
  18. Google Pixel 5a Rear Camera Replacement, Remove the black plastic cover: étape 18, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Remove the black plastic cover: étape 18, image 2 de 2
    • Use the pointed end of a spudger to pry up on the black plastic cover at the bottom left of the phone.
    Demander à FixBot
  19. Google Pixel 5a Rear Camera Replacement: étape 19, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 19, image 2 de 2
    • Slide the pointed end of the spudger left until the plastic cover is completely separated from the midframe.
    • Remove the plastic cover from the midframe.
    Demander à FixBot
  20. Google Pixel 5a Rear Camera Replacement: étape 20, image 1 de 3 Google Pixel 5a Rear Camera Replacement: étape 20, image 2 de 3 Google Pixel 5a Rear Camera Replacement: étape 20, image 3 de 3
    • Use a pair of tweezers to slightly peel back the tape concealing the two screws securing the charging port bracket.
    Demander à FixBot
  21. Google Pixel 5a Rear Camera Replacement, Remove the remaining screws: étape 21, image 1 de 1
    • Use a T3 Torx driver to remove the remaining four screws securing the midframe to the motherboard:
    • Three 4.6 mm screws
    • One 4.0 mm screw
    Demander à FixBot
  22. Google Pixel 5a Rear Camera Replacement: étape 22, image 1 de 2 Google Pixel 5a Rear Camera Replacement: étape 22, image 2 de 2
    • Use a spudger or a pair of tweezers to peel back the tape securing the charging port bracket to the speaker assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    Demander à FixBot
  23. Google Pixel 5a Rear Camera Replacement: étape 23, image 1 de 3 Google Pixel 5a Rear Camera Replacement: étape 23, image 2 de 3 Google Pixel 5a Rear Camera Replacement: étape 23, image 3 de 3
    • Use a blunt pair of tweezers, or your fingers, to carefully peel back the graphite sheet covering the battery.
    • Be careful not to accidentally puncture or otherwise damage the battery when gripping the graphite sheet.
    Demander à FixBot
  24. Google Pixel 5a Rear Camera Replacement, Detach the midframe: étape 24, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Detach the midframe: étape 24, image 2 de 2
    • Insert the pointed end of a spudger under the top right corner of the midframe.
    • There is a black plastic clip at the top of the midframe that secures it to the top of the frame. To detach it, use the spudger to pull the midframe down and then pry up.
    Demander à FixBot
  25. Google Pixel 5a Rear Camera Replacement, Remove the midframe: étape 25, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Remove the midframe: étape 25, image 2 de 2
    • Remove the midframe.
    Demander à FixBot
  26. Google Pixel 5a Rear Camera Replacement, Replace the plastic bits: étape 26, image 1 de 3 Google Pixel 5a Rear Camera Replacement, Replace the plastic bits: étape 26, image 2 de 3 Google Pixel 5a Rear Camera Replacement, Replace the plastic bits: étape 26, image 3 de 3
    • There are two small plastic bits that help hold the midframe in place. Take care not to misplace them, as without the midframe to hold them in place, they are very easy to lose.
    • Be sure to place these back into their respective corners before replacing the midframe when reassembling your device.
    Demander à FixBot
  27. Google Pixel 5a Rear Camera Replacement, Disconnect the battery: étape 27, image 1 de 2 Google Pixel 5a Rear Camera Replacement, Disconnect the battery: étape 27, image 2 de 2
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
    Demander à FixBot
  28. Google Pixel 5a Rear Camera Replacement, Remove the 16 MP Ultrawide camera: étape 28, image 1 de 3 Google Pixel 5a Rear Camera Replacement, Remove the 16 MP Ultrawide camera: étape 28, image 2 de 3 Google Pixel 5a Rear Camera Replacement, Remove the 16 MP Ultrawide camera: étape 28, image 3 de 3
    • Use the flat end of a spudger to pry up on the 16 MP Ultrawide camera's connector to disconnect it.
    • Remove the 16 MP Ultrawide camera.
    Demander à FixBot
  29. Google Pixel 5a Rear Camera Replacement, Remove the 12.2 MP Wide-Angle camera: étape 29, image 1 de 3 Google Pixel 5a Rear Camera Replacement, Remove the 12.2 MP Wide-Angle camera: étape 29, image 2 de 3 Google Pixel 5a Rear Camera Replacement, Remove the 12.2 MP Wide-Angle camera: étape 29, image 3 de 3
    • Use the flat end of a spudger to pry up on the 12.2 MP Wide-Angle camera's connector to disconnect it.
    • Remove the 12.2 MP Wide-Angle camera.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 5a Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Kim
Membre depuis le 02/16/21
13 239 Réputation
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 40
Total : 1,953
