Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 7 Motherboard Replacement
Ce dont vous avez besoin
  1. Google Pixel 7 Motherboard Replacement, Safety precautions: étape 1, image 1 de 2 Google Pixel 7 Motherboard Replacement, Safety precautions: étape 1, image 2 de 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 7 Motherboard Replacement, Screen removal information: étape 2, image 1 de 3 Google Pixel 7 Motherboard Replacement, Screen removal information: étape 2, image 2 de 3 Google Pixel 7 Motherboard Replacement, Screen removal information: étape 2, image 3 de 3
    • The screen of the Google Pixel 7 is held in place by a safety frame of plastic clips and adhesive.
    • During the removal procedure, make sure to insert your opening picks under the safety frame to avoid separating it from the screen.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
    Demander à FixBot
  3. Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 Google Pixel 7 Motherboard Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Demander à FixBot
  4. Google Pixel 7 Motherboard Replacement: étape 4, image 1 de 3 Google Pixel 7 Motherboard Replacement: étape 4, image 2 de 3 Google Pixel 7 Motherboard Replacement: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Demander à FixBot
  5. Google Pixel 7 Motherboard Replacement: étape 5, image 1 de 3 Google Pixel 7 Motherboard Replacement: étape 5, image 2 de 3 Google Pixel 7 Motherboard Replacement: étape 5, image 3 de 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Demander à FixBot
  6. Google Pixel 7 Motherboard Replacement, Loosen the display adhesive: étape 6, image 1 de 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Demander à FixBot
  7. Google Pixel 7 Motherboard Replacement, Insert an opening pick: étape 7, image 1 de 3 Google Pixel 7 Motherboard Replacement, Insert an opening pick: étape 7, image 2 de 3 Google Pixel 7 Motherboard Replacement, Insert an opening pick: étape 7, image 3 de 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
    Demander à FixBot
  8. Google Pixel 7 Motherboard Replacement, Prevent damage to your phone: étape 8, image 1 de 2 Google Pixel 7 Motherboard Replacement, Prevent damage to your phone: étape 8, image 2 de 2
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Demander à FixBot
  9. Google Pixel 7 Motherboard Replacement, Slice the bottom edge adhesive: étape 9, image 1 de 2 Google Pixel 7 Motherboard Replacement, Slice the bottom edge adhesive: étape 9, image 2 de 2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Demander à FixBot
  10. Google Pixel 7 Motherboard Replacement: étape 10, image 1 de 2 Google Pixel 7 Motherboard Replacement: étape 10, image 2 de 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    Demander à FixBot
  11. Google Pixel 7 Motherboard Replacement, Release the left clips: étape 11, image 1 de 3 Google Pixel 7 Motherboard Replacement, Release the left clips: étape 11, image 2 de 3 Google Pixel 7 Motherboard Replacement, Release the left clips: étape 11, image 3 de 3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  12. Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: étape 12, image 1 de 3 Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: étape 12, image 2 de 3 Google Pixel 7 Motherboard Replacement, Slice the top edge adhesive: étape 12, image 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  13. Google Pixel 7 Motherboard Replacement, Release the right clips: étape 13, image 1 de 3 Google Pixel 7 Motherboard Replacement, Release the right clips: étape 13, image 2 de 3 Google Pixel 7 Motherboard Replacement, Release the right clips: étape 13, image 3 de 3
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
    Demander à FixBot
  14. Google Pixel 7 Motherboard Replacement, Open up the phone assembly: étape 14, image 1 de 3 Google Pixel 7 Motherboard Replacement, Open up the phone assembly: étape 14, image 2 de 3 Google Pixel 7 Motherboard Replacement, Open up the phone assembly: étape 14, image 3 de 3
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame before continuing.
    Demander à FixBot
  15. Google Pixel 7 Motherboard Replacement, Release the display cable bracket: étape 15, image 1 de 2 Google Pixel 7 Motherboard Replacement, Release the display cable bracket: étape 15, image 2 de 2
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
    Demander à FixBot
  16. Google Pixel 7 Motherboard Replacement, Remove the display cable bracket: étape 16, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the display cable bracket: étape 16, image 2 de 2
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
    Demander à FixBot
  17. Google Pixel 7 Motherboard Replacement, Disconnect the display cable: étape 17, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the display cable: étape 17, image 2 de 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Demander à FixBot
  18. Google Pixel 7 Motherboard Replacement, Screen information: étape 18, image 1 de 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Demander à FixBot
  19. Google Pixel 7 Motherboard Replacement, Separate the screen: étape 19, image 1 de 1
    • Separate the screen from the phone.
    • During reassembly:
    • Check that all screws are tightened and there are no loose parts.
    • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Demander à FixBot
  20. Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: étape 20, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: étape 20, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the black silicone pad: étape 20, image 3 de 3
    • Take care not to puncture or bend the battery with your tool in the following steps—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of tweezers to peel the black silicone pad off the battery and midframe.
    Demander à FixBot
  21. Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: étape 21, image 1 de 3 Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: étape 21, image 2 de 3 Google Pixel 7 Motherboard Replacement, Peel off the upper graphite foil: étape 21, image 3 de 3
    • Use a pair of tweezers to carefully peel the upper graphite foil off the battery and midframe.
    • If you're having a hard time peeling off the foil, apply a heated iOpener to the foil for two minutes to loosen its adhesive.
    Demander à FixBot
  22. Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: étape 22, image 1 de 3 Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: étape 22, image 2 de 3 Google Pixel 7 Motherboard Replacement, Peel off the lower graphite foil: étape 22, image 3 de 3
    • Use a pair of tweezers to carefully peel the lower graphite foil off the battery and midframe.
    Demander à FixBot
  23. Google Pixel 7 Motherboard Replacement, Unfasten the loudspeaker screws: étape 23, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the loudspeaker screws: étape 23, image 2 de 2
    • Use a Torx T3 screwdriver to remove the three 5.1 mm-long screws securing the loudspeaker.
    Demander à FixBot
  24. Google Pixel 7 Motherboard Replacement, Remove the loudspeaker: étape 24, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the loudspeaker: étape 24, image 2 de 2
    • Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
    Demander à FixBot
  25. Google Pixel 7 Motherboard Replacement, Unfasten the midframe screws: étape 25, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the midframe screws: étape 25, image 2 de 2
    • Use a Torx T3 screwdriver to remove the nine 5.1 mm-long screws securing the midframe.
    Demander à FixBot
  26. Google Pixel 7 Motherboard Replacement, Remove the midframe: étape 26, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the midframe: étape 26, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the midframe: étape 26, image 3 de 3
    • Use a pair of tweezers to remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
    Demander à FixBot
  27. Google Pixel 7 Motherboard Replacement, Disconnect the battery cable: étape 27, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the battery cable: étape 27, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Demander à FixBot
  28. Google Pixel 7 Motherboard Replacement, Heat the battery's adhesive: étape 28, image 1 de 1
    • Apply a heated iOpener to the back of the device to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    Demander à FixBot
  29. Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: étape 29, image 1 de 3 Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: étape 29, image 2 de 3 Google Pixel 7 Motherboard Replacement, Separate the battery pull tabs: étape 29, image 3 de 3
    • Use tweezers, or your fingers, to peel the plastic pull tabs away from the battery.
    Demander à FixBot
  30. Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: étape 30, image 1 de 3 Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: étape 30, image 2 de 3 Google Pixel 7 Motherboard Replacement, Separate the battery's adhesive: étape 30, image 3 de 3
    • Pull the tabs back and forth in a sawing motion up the length of the battery to separate the adhesive underneath.
    • Work slowly. It's easy to lose your grip and accidentally pull the tab up from under the battery.
    • If you're having difficulty separating the adhesive, apply more heat and wait for the adhesive to loosen.
    • If you lose or tear the release strip, follow the next step for an alternative battery removal method.
    Demander à FixBot
  31. Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: étape 31, image 1 de 3 Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: étape 31, image 2 de 3 Google Pixel 7 Motherboard Replacement, How to remove a stuck battery: étape 31, image 3 de 3
    • Follow this step if you couldn't loosen the battery using the battery release strip.
    • Apply a few drops of high concentration (90% or higher) isopropyl alcohol into the gap at the top edge of the battery.
    • Don't apply too much alcohol, or you'll loosen the NFC antenna and charging coil underneath the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a spudger or an opening pick to gently lift the top edge of the battery until you can grab it with your fingers.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that's required to free it from the frame.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    Demander à FixBot
  32. Google Pixel 7 Motherboard Replacement, Remove the battery: étape 32, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the battery: étape 32, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the battery: étape 32, image 3 de 3
    • Tilt the battery out of the device to separate the rest of the adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • To secure the replacement battery:
    • Apply pre-cut adhesive adhesive or double-sided tape to the battery well at the places where the old adhesive was located, not directly onto the battery.
    • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
    • Make sure that the battery sits in the center of the battery well and there's an even gap around the battery.
    • Press the new battery firmly into place.
    Demander à FixBot
  33. Google Pixel 7 Motherboard Replacement, Unfasten the mmWave antenna bracket screw: étape 33, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the mmWave antenna bracket screw: étape 33, image 2 de 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the mmWave antenna bracket.
    Demander à FixBot
  34. Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna bracket: étape 34, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna bracket: étape 34, image 2 de 2
    • Use a pair of tweezers to remove the mmWave antenna bracket.
    Demander à FixBot
  35. Google Pixel 7 Motherboard Replacement, Disconnect the mmWave antenna cable: étape 35, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the mmWave antenna cable: étape 35, image 2 de 2
    • Use a spudger to disconnect the mmWave antenna cable by prying the connector straight up from its socket.
    Demander à FixBot
  36. Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: étape 36, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: étape 36, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the mmWave antenna assembly: étape 36, image 3 de 3
    • Use a pair of tweezers to lift the mmWave antenna including its cable out of its recess.
    • Remove the mmWave antenna assembly.
    Demander à FixBot
  37. Google Pixel 7 Motherboard Replacement, Remove the thermal paste: étape 37, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the thermal paste: étape 37, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the thermal paste: étape 37, image 3 de 3
    • Use the flat end of a spudger to scrape the thermal paste off the mmWave antenna.
    • Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
    • Repeat the cleaning process for the thermal paste on the mmWave antenna bracket.
    • During reassembly, follow this guide for reapplying thermal paste onto the mmWave antenna.
    Demander à FixBot
  38. Google Pixel 7 Motherboard Replacement, Disconnect the front facing camera: étape 38, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the front facing camera: étape 38, image 2 de 2
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
    Demander à FixBot
  39. Google Pixel 7 Motherboard Replacement, Remove the front facing camera: étape 39, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the front facing camera: étape 39, image 2 de 2
    • Use a pair of tweezers to lift the front facing camera out of its recess and remove it.
    Demander à FixBot
  40. Google Pixel 7 Motherboard Replacement, Unfasten the rear camera screw: étape 40, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the rear camera screw: étape 40, image 2 de 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the rear cameras.
    Demander à FixBot
  41. Google Pixel 7 Motherboard Replacement, Disconnect the wide-angle camera cable: étape 41, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the wide-angle camera cable: étape 41, image 2 de 2
    • Use a spudger to disconnect the wide-angle camera cable by prying the connector straight up from its socket.
    Demander à FixBot
  42. Google Pixel 7 Motherboard Replacement, Remove the wide-angle camera: étape 42, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the wide-angle camera: étape 42, image 2 de 2
    • Use a pair of tweezers to remove the wide-angle camera.
    Demander à FixBot
  43. Google Pixel 7 Motherboard Replacement, Disconnect the ultra wide-angle camera cable: étape 43, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the ultra wide-angle camera cable: étape 43, image 2 de 2
    • Use a spudger to disconnect the ultra wide-angle camera cable by prying the connector straight up from its socket.
    Demander à FixBot
  44. Google Pixel 7 Motherboard Replacement, Remove the ultra wide-angle camera: étape 44, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the ultra wide-angle camera: étape 44, image 2 de 2
    • Use a pair of tweezers to remove the ultra wide-angle camera.
    Demander à FixBot
  45. Google Pixel 7 Motherboard Replacement, Unfasten the earpiece speaker screw: étape 45, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the earpiece speaker screw: étape 45, image 2 de 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the earpiece speaker.
    Demander à FixBot
  46. Google Pixel 7 Motherboard Replacement, Pry up the earpiece speaker: étape 46, image 1 de 2 Google Pixel 7 Motherboard Replacement, Pry up the earpiece speaker: étape 46, image 2 de 2
    • Insert the pointed end of a spudger underneath the bottom edge of the earpiece speaker.
    • Pry upwards to loosen the earpiece speaker.
    Demander à FixBot
  47. Google Pixel 7 Motherboard Replacement, Remove the earpiece speaker: étape 47, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the earpiece speaker: étape 47, image 2 de 2
    • Use a pair of tweezers to remove the earpiece speaker.
    Demander à FixBot
  48. Google Pixel 7 Motherboard Replacement, Disconnect the microphone interconnect cable: étape 48, image 1 de 2 Google Pixel 7 Motherboard Replacement, Disconnect the microphone interconnect cable: étape 48, image 2 de 2
    • Use a spudger to disconnect the microphone interconnect cable by prying the connector straight up from its socket.
    Demander à FixBot
  49. Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: étape 49, image 1 de 3 Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: étape 49, image 2 de 3 Google Pixel 7 Motherboard Replacement, Eject the SIM card tray: étape 49, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    Demander à FixBot
  50. Google Pixel 7 Motherboard Replacement, Remove the SIM card tray: étape 50, image 1 de 2 Google Pixel 7 Motherboard Replacement, Remove the SIM card tray: étape 50, image 2 de 2
    • Remove the SIM card tray.
    Demander à FixBot
  51. Google Pixel 7 Motherboard Replacement, Unfasten the motherboard screw: étape 51, image 1 de 2 Google Pixel 7 Motherboard Replacement, Unfasten the motherboard screw: étape 51, image 2 de 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the motherboard.
    Demander à FixBot
  52. Google Pixel 7 Motherboard Replacement, Pry up the motherboard: étape 52, image 1 de 2 Google Pixel 7 Motherboard Replacement, Pry up the motherboard: étape 52, image 2 de 2
    • Make sure the motherboard isn't blocked or tangled by any cables during this step.
    • Insert a spudger underneath the top edge of the motherboard.
    • Pry upwards to loosen the motherboard until you can grab it with your fingers.
    Demander à FixBot
  53. Google Pixel 7 Motherboard Replacement, Remove the motherboard: étape 53, image 1 de 3 Google Pixel 7 Motherboard Replacement, Remove the motherboard: étape 53, image 2 de 3 Google Pixel 7 Motherboard Replacement, Remove the motherboard: étape 53, image 3 de 3
    • Grab the top end of the motherboard with your fingers.
    • Pull the motherboard in direction of the top edge of the frame to free the charging port from its recess.
    • Remove the motherboard.
    • Compare your new replacement part to the original part—you may need to transfer components like the antenna cables to your new motherboard.
    Demander à FixBot
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
8 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
261 738 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
31 535 tutoriels rédigés
2 commentaires de tutoriel
Hey, i am very glad to found your guide for Pixel 7 board replacement. And i have a question - i had my Pixel 7 died. Was at repair center, the tech said motherboard is just died . They have not this part . Please can you help me with finding of Pixel 7 board like a replacement part ? You can email me at vanko.68@gmail.com
Thanks in advance!
aidavanko - Réponse Partager
eBay has broken Google Pixel 7s I just bought a broken with and used the motherboard out of that it's around 75.00 to a hundred.
Elliott sanderson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 97
30 derniers jours : 470
Total : 18,343
