Aller au contenu principal
These repair guides are for a 2007-2012 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
20 questions Voir tout
Oil leak near timing chain
Have and oil leak near oil pan and harmonic balancer in my 2007 unlimited sahara edition wrangler
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
what engine is it,4.0?
par
3.8 v-6 engine
par
Ajouter un commentaire
2 Réponses
Solution retenue
Could be the oil pan gasket. Spray it off with some engine cleaner and investigate where it leaks from. take a couple of pictures and post those on here.There is also the oil pump that is in the front cover, driven from the front of the crankshaft. Oil passes in and out of the front cover through the timing cover gaskets which may have failed. A failed front crank seal will usually fling oil off the damper and soak the area.
Indice 2
Oil consum engine 08 wrangler
Indice 0
1 commentaire:
Sergo Saintil, I suppose you mean to ask a question:-) What exactly do you want to find out about?
par
Ajouter une réponse
Miguel Guebara sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 2,069
