Aller au contenu principal
A laptop by Toshiba in the L350 series with a 17" display, released in August 2009.
My computer shuts down soon after it starts up!
when i press the start button in the laptop it takes much time to open (more than 2 minutes) then it shuts down by its own i don't press any button
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
Mine, if run on battery is won't shutdown but when plug it shutdown any solution pls
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
When you write "time to open" I assume you mean the system boots up and loads your OS, but suddenly it shuts down. Is it correct?
If so, check you system fan, because the problem seems to be caused by an overheating and the laptop shuts down to prevent damages.
Other thing you can check is the thermal paste condition, or even if the heat sink is correctly screwed to the mounting holes.
Indice 4
Ajouter une réponse
monet sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 508
