Aller au contenu principal
7.1 megapixel camera by Canon, model SD750.
9 questions Voir tout
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
6 commentaires
No memory card in my camera
par
Use the camera to reformat the card.
par
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
par
When it says no card what will you firmat bro
par
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
par
Afficher 1 commentaire en plus
Ajouter un commentaire
1 Réponse
Solution retenue
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
Indice 1
4 commentaires:
Did you get my last response?
par
I guess not. All I got was that one
par
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
par
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
par
Ajouter une réponse
mesarey sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 5,104
