Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Streak was released on August 13, 2010 and is exclusively available on AT&T's cellular network in the US.
Can I replace the Speaker
The speaker on this device is totally rubbish. It cracks and crackles, the speakerphone is almost unusable. Is the part easily replaceable and if so can you recommend a compatible excellent replacement?
The ear speaker is also horrible in that you cannot hear anything unless you've absolutely directly paired your ear canal and the tiny slit. Any suggestions of a solution for a louder speaker here?
Thanks, Ravi Shanghavi, Ottawa
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
I have had people tell me that "removing the cover over speaker helps with sound volume" so I gave it a try and will describe how to here. I will assume that you saw the teardown post for that is the best how to guide I've seen to date. For this mod you only need to remove the plastic bezel that covers the internal speaker.
Once cover is removed (it is held on with rather sticky tape so be careful not to crack it. I reccomend using the plastic tools shown in teardown post) locate the sticker covering the speaker
using tweezers, or whatever floats your boat, to peel off sticker.
Now simply replace the plastic bezel. I noticed a slight difference is sound, especially with directionality. I no longer have to have slit directly over my ear canal. Slightly off center works well now.
Indice 0
Équipez-vous pour vos futures réparations
Ajouter une réponse
Ravi Shanghavi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 2,210
