Aller au contenu principal
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
20 questions Voir tout
2 beeps,black screen plz help
i hold the power button for a couple seconds and it beeps 2 times i tried taking the battery out and couple more things and it beeped yesterday then i toke the battery out and turned it back on with the battery on it worked .PLZ help me
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
brittany2015, 2 beep POST beep is a No Memory (RAM) detected error. This could be the memory module as well as the memory slot failure. If you have more than one module. Pull one at a time and see if it POST properly. If you only have one, you may need to re-seat it or clean the contacts where it sits in the memory slot. If that does not fix it, and if your able to see the Dell Logo at startup, press F12 at that page. Select Diagnostics, and run an extended diagnostics on your computer. Worst case scenario is a slot failure which would require a new motherboard.
Indice 4
2 commentaires:
i tried the F12 thing it didnt work but thanks for your help
par
This can also to be the cmos battery my cmos battery is dead and removing that battry the computer boots up to say cmos battery failure but if u press F1 it will boot to the os and if there is no os it will just say no os.
par
I know this is an old thread but it came up when I googled my problem so I imagine it must come up for others as well. I had a black screen with a double beep alarm. I took it to geek squad where they told me that it was 70$ to run diagnostic and 350$ to replace parts. I took my dell home and removed the. Artery and the panel on the bottom with the small screw. Inside the memory panel is right in front of you. U click the little grey plastic holders on the side and the memory card will tilt upwards so you can slide it out. Just like an SD card. Take it out and reconnect it. My computer works like a charm. Hope this helps.
Indice 1
1 commentaire:
thanks for taking the time..
par
Ajouter une réponse
brittany2015 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 20
Total : 11,578
