Aller au contenu principal
La Nintendo 3DS XL 2015, vendu en tant que New Nintendo 3DS XL, est sortie le 11 octobre 2014 au Japon et le 13 février 2015 en Amérique du Nord.
How can I just swap the outer shells/casing?
Thanks for reading this much!
All I want to do is swap the outer shells or casing or whatever they're called. I have a blue new 3DS XL and I want to swap the colour for a black one. My friend was going to sell hers, but was kind enough to give it to me so I have all the materials I should need in that regard.
Let me make it clear; I do not want to change anything but the very outer casings. I have a vague understanding of how to swap the bottom one, but I am confused on the top one. Every tutorial that I've looked at has had people unscrewing things on the inside of the top, but if all I want to do is change the outer casing, then will I still need to do that? I feel like it should just come off, if I'm not changing the inside.
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
1. There are hidden screws.
2. Find those hidden screws
3. Unscrew them.
4. Its a barbed lock in system thats holding you back. If no more than 1 $@$* is given about the old case, use a mini flat head and pop it out. Otherwise you should accept that this is a very rough swap. Once the bottom is out, follow the same case popping trick for the top between the divide of the black and blue/red/black/etc. It'll be there no matter what but if you slip then you risk gnashing the screen with a steel driver so BE CAREFUL! (I speak from experience)
Indice 0
Ajouter une réponse
Taylor Prince sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,322
