Multimeter continuous beeping in continuity mode
continuous beeping even with test leads removed.
checked battery and opened it up with no showing of corrosion or something shorting anything. Fuse still intact also did not work with high voltages.
Was checking some dead phone batteries at the time and when got back to it it kept beeping.
does not want to work in any other mode at all.
10 commentaires
What type of model and make of Multimeter do you have?
par gillrios
It just says Digital Multimeter DT369.
It isn't the clamp model I found when looking for a service model though.
par Francois Saaiman
added pic of Multimeter if that helps.
Hmm. That's one of those economical run-of-the-mill (but nonetheless useful, when they work) chinese meters. Well, you're going to have to buy a new one anyway if you'd want to troubleshoot this one ;)
par Flying Dutchman
Same problem found in UT-33D giving continue beeping without probes only on Diod mode
par Saleem Iqbal
Voir 5 commentaires en plus
