Aller au contenu principal
Pour réparer ensemble - Je crée un compte
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Phone will not charge
My phone will not charge. All it does when I plug charger in. Screen stays at 0% (screen shows this) but that's it.. will not charge
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
4 Réponses
Solution retenue
Try replacing the battery like the other comment said. At my phone shop that would be one of the first things we would try. Also try a different charger that might be the issue, the charger you are currently using may not be giving out enough power to charge the battery.
Indice 4
First step would be to replace the battery.
Indice 1
Did that, replaced the grey battery with an aftermarket one off Ebay. It's been 8 months. Now the phone won't charge again. Did the USB cleaning. Changed chargers. Still it gets hot when charging. Won't charge phone says “slow charge” not sure what to do next
Indice 0
I done everything change battery change charger.its says 0 charging charge before using I put on charging 5 hour same problem showing me again
Indice 0
Ajouter une réponse
tamrobbins sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 3,929
