Aller au contenu principal
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
20 questions Voir tout
Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
student question
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Test the power cord with a multimeter like in this guide.
Test de la continuité d'un cordon d'alimentation
Then I would also test the power adapter is it is working with the multimeter
Comment utiliser un multimètre
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Image Electrical
Tutoriel
Difficulté :
Très facile
1 - 5 minutes
Image Electronics Skills
Tutoriel
Difficulté :
Facile
5 minutes
Indice 2
Try replacing the battery or buying a new charger.
Indice 0
1 commentaire:
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
par
Ajouter une réponse
Lino Virgen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 403
