Aller au contenu principal
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
20 questions Voir tout
Only Fan turns on when holding power button
Hi!
So my problem is, that my Lenovo Y50-70 wont turn on at all. Only the fan starts when holding the power or recovery button. (Fan only works for 10 secs. then the whole laptop is quiet, USB 3.0 Ports has Voltage the 10 secs. fan is running)
would be nice if i get an answear here.
Maybe the Problem is electrostatic charge. but since i cant remove the battery i ve no idea how to make a discharge.
Regards,
flo071
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Did you ever find a solution to this? I just ran into the same issue...
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
One method of doing a hard reset is to remove the power cord and press the power button for 20 seconds.
Another method is, with a low battery and while charging, press and hold power button until the battery LED is off, then immediately pull the cable, release the power button, and try to power it on again.
UPDATE: Ok, I know this is an old thread but since that didn't work - have you checked the RAM?
Indice 1
7 commentaires:
The only problem is, that the battery is not removable.
But thanks anyways for your fast answer. :)
par
No problem. Give it a try though, this advice is specific to your model, so it might fix the problem.
par
tried both of them. Sadly nothing worked. Is there any other method?
Thanks!
par
flo071, did you ever fix this? I just ran into the exact issue...
par
Matthew, have you checked your RAM?
par
Voir 2 commentaires en plus
Ajouter une réponse
flo071 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 2,843
