Aller au contenu principal
The Nokia E7-00 phone is a business-oriented smartphone with a built-in keyboard. It was released in 2011.
1 questions Voir tout
How to change the USB port?
The USB port of my Nokia E7-00 has some bad contacts, depending on the angle of the USB wire with the phone, the phone is not charging or unable to transfer data to a plugged computer. I would like to change it but I don't know how and I'm a little bit affraid of trying without any advices.
I'll be very glad if someone could help me about this.
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
1 Réponse
i finally had a go at analyzing this common failure ...
the root cause is that the plastic part within the usb port has/develops a tiny amount of wiggle room. this wiggle ultimately causes the outer pins to snap off right in the "knee" of the "L" shape which attaches to the PCB.
you can replace the socket (it costs "nothing"), or you can solder tiny bent wires to it - i did the latter, and it actually worked (dunno for how long).
you will need a hot air gun, a preheating plate (the motherboard sinks so much heat that there is no way hot air alone will be enough), flux, and a little fresh solder. if you do the wire magic, you'll also need equipment for soldering tiny parts - a short-shafted pointy soldering tip (J shape), a magnifier, and a sufficiently steady hand.
you can try closing the gaps in the broken leads while the socket is still soldered, but i don't think it will work, as the solder is unlikely to flow that deep, esp. with the enormous heat-sinking of the PCB.
Indice 0
Ajouter une réponse
Sylvain sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 598
