Aller au contenu principal
Pour réparer ensemble - Je crée un compte
laptop is very hot and has a high pitched squeak
My laptop gets very hot and makes a high pitched squeak.
How do I fix it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
It is probably the fan. Remove the bottom case and check the fan for obstructions and dust. The fan should spin freely, if not then replace it. The next thing to do is to remove the heatsink from the processor and clean the old heatsink compound off and put in fresh heatsink compound onto the heatsink (apply a small amount, too much will just get squeezed out).
par
Ajouter un commentaire
1 Réponse
Solution retenue
@lasdisc , ANDY, It very well could be a dirty fan or a faulty fan. You can use the links below to assist in opening the computer to access the fan, heat sinks, board etc. and give the inside of the laptop a thorough cleaning as shown in the 1st link. 3rd link is your service manual. You should try to isolate where the noise is coming from before opening the laptop, by chance that it is not the fan. If fan is not spinning freely or you may just not trust it, maybe just replace it for piece of mind, Link #4 shows replacement fan, which you can also do a search on for better pricing perhaps. Good luck.
https://www.youtube.com/watch?v=ZT0ovCnt...
https://www.youtube.com/watch?v=VvJwlTcp...
http://www.hp.com/ctg/Manual/c03591253.p...
https://www.amazon.com/FEBNISCTE-dv7-721...
Indice 3
Ajouter une réponse
ANDY sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 2,527
