Aller au contenu principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Questions au sujet de 146 Voir tout
Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
Where is the fuse located inside the car or under the hood
par
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
par
Where are the headlight fuses??
par
Ajouter un commentaire
2 Réponses
Solution retenue
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
Indice 1
how does this help me find the fuse and or fuse box
Indice 0
2 commentaires:
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
par
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
par
Ajouter une réponse
Frank sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 18
Total : 32,867
