Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Un appareil photo bridge, hybride et compact sorti en janvier 2013, doté d'une résolution de 16 mégapixels, d'une ouverture réglable et d'un zoom 30x. Il pèse un peu moins de 500 g, ce qui est idéal pour les photographes itinérants.
Why won't my camera's lens retract?
I was taking pictures out in front of my house and I dropped my camera on the concrete. Now, the lens won't go back into the body of the camera. How do I fix this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
You will probably need to send it back to fujifilm
par
Ajouter un commentaire
2 Réponses
Solution retenue
@calabrese ,Stephen, The camera lens has a very small delicate set of gears inside which control the lens movement and when the camera was dropped the meshing off these gears were probably thrown out of alignment. It is not recommended for the inexperienced to try a repair on a lens. Best to pop into a good local camera shop and have them take a look and estimate repair.
What you can do is check for any dust/debri/sand etc., that may be stuck between the lens barrel and where it retracts into camera and use something thin(small strip of paper) and go all the way around the lens barrel and pick dust/debri out, to see if it was being jammed by dust/debri/etc.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Indice 4
This camera is prone to lens issues after being dropped, especially on to something hard like concrete. There is a section on the troubleshooting page regarding this issue.
If you are unable to fix your device using the steps shown in on the troubleshooting page, the lens may be irreparably damaged. Please check out our guide for replacing this camera's lens.
Indice 0
Ajouter une réponse
Stephen Calabrese sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 43
Total : 10,182
