Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
20 questions Voir tout
Has sound but no picture
KDL-40W600B
I have the EXACT same issue as the person who started this thread. Same TV model and age. The picture went blank, but had sound and could change channels. Did a factory reset and lost the sound. Turning on the TV - I get the green power light and that's all.
I'm not an EE, but I'm pretty handy with a soldering iron and build PCs all the time (I just changed the LED screen in my son's ASUS laptop). So, if this can be fixed by a new component, I'd be up for the challenge (heck, a few months ago, I successfully changed the transmission in my '04 Explorer, but I wouldn't do it again if I have the $'s to pay a mechanic - wasn't the least bit fun!).
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@jefftx proceed the same way as it was suggested in the previous question where your "question" was left as an Answer to. Proceed by following the triage chart for your model
and let us know what you find. We still need more info to see if any LED is blinking. you can also post some images of your boards with your question. Use this guide Ajout d'images à une question existante for that. Since you have audio but no video I would concentrate on the LVDS cables and the T-Con board. Most T-con boards are fused, so check the fuse for continuity. Also, check the power board for any obvious damaged components, like domed or leaking caps etc. The number one suspect on this is the the main board followed by the tuner board. Once you remove the back cover turn your TV on and see if you can make out the backlight through some of the holes on the back of the panel cover.
Indice 1
Ajouter une réponse
Jeff sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 7,551
