Aller au contenu principal
Il s’agit de la version 2015 d’une longue série d’ordinateurs portable produite par Toshiba. Cet appareil est un ordinateur performant, mais qui est également très abordable, ce qui en fait un bon choix pour les étudiants.
5 questions Voir tout
C55T A5103 serial number
Hi, what kind of USB ports should I buy from your store to replace them with my computer's defective USB ports? Is there identification number for them? I have Toshiba satellite C55t A5103 laptop and I want to replace the USB ports that are on the right side and not the one near the power port of the computer. Please let me know. Thanks
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Is the USB ports soldered in place with the motherboard?
Indice 0
2 commentaires:
Hi, yes it is attached to the motherboard and I want to replace them if you have the right USB port
par
you can solder it off and solder a new one . Hope it works!
par
There are only two options for you: Replace the motherboard, or use a USB hub.
Replacing the motherboard would be major surgery. If you don't know exactly what you are doing, you can damage it in the process.
A USB hub, on the other hand, simply plugs in and gives you more USB ports. In your case, it would be more USB2 ports, because your USB3 ports are on the bad side of the computer.
If you decide to go with a USB hub, make sure you get one which has its own power, that is, one which has an AC adapter. Sometimes devices won't be able to draw sufficient power when plugged into a hub, unless that hub has its own power.
Indice 0
Ajouter une réponse
hamza chaghlil sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 218
