Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Canon Powershot A590 IS est un appareil photo numérique compact de 8 mégapixels doté d'un zoom optique 4x et d'un écran LCD de 2,5 pouces.
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
4 Réponses
Solution retenue
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
Indice 2
lens do not get back when on/off button is pressed.
Indice 2
1 commentaire:
same answer as above :-)
par
make sure you are not holding the lens when you turn the camera on.
Indice 1
can you help for restart the camera
Indice 1
1 commentaire:
Camera lens does not move when switch.
par
Ajouter une réponse
Pinky Kasotia sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 34
Total : 6,629
