Aller au contenu principal
Le successeur du smartphone LG V10, similaire au LG G5, commercialisé le 29 septembre 2016. Le LG V20 se reconnaît aux numéros de modèle F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996 et VS995.
20 questions Voir tout
How can I get my display to work again?
My screen came out so I took the phone apart and re-glued the screen with some 1mm 3M tape. Now I reassembled it and it vibrates on boot and I can see the backlight go on because a corner of the screen is broken off… Also WhatsApp Web works. So the phone is definitely working, but the display isnt showing anything (Backlight does work tho)… I re-checked the main screen connector at the bottom and it is properly plugged… what can I do?
P.S.: I followed this tutorial for the process: https://www.youtube.com/watch?v=oDEZjsqN...
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
The LCD is for sure broken. In order to get a display back, you will need to replace the screen.
part can be found here: https://www.fixez.com/store/lg/lg-v-seri...
Having a screen with frame saves you the hassle of having to re adhere the screen to its frame, so personally I would go with that part.
Repair tutorial here: Remplacement de l'écran du LG V20
Note: If you buy the screen with frame, you start putting your phone back together after step 15 in that repair guide, if you buy screen only, you will follow the entire tutorial.
Indice 0
Ajouter une réponse
Raphael Nollau (R4PHikari) sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 227
