Aller au contenu principal
Repair information and troubleshooting for the Harman Kardon Aura Studio 2, a bluetooth speaker with a microphone made by Harman Kardon and smaller than the Aura.
19 questions Voir tout
not powering up when touching the panel
when connect to the power internal led blink once then touch the panel to power up the unit nothing happen. I have checked the power adapter by using multi-meter and it’s reading was 18.3v( adapter back side marked as 19v)
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
4 Réponses
Réponse la plus utile
It’s an easy fix. You have to disassemble speaker from bottom, remove screws, etc. Remove sensor ribbon and replace with a new one. I hope this helps you.
Indice 2
5 commentaires:
Hola Marcelino González no sé si me puedes ayudar tengo 1 Harman kardon aura no prende y al abrir me fijé que tiene roto el plástico que lleva dentro pegado al entendido este es mi correo electrónico paparealmadrid@ail.com si me puedes ayudar gracias
par
Thanks for the suggestion, could you share the part number for the sensor ribbon or where it can be purchased please? I can manage to find it :-(
Thanks again
par
Were you ever able to fix this? I’m having the same issue
par
Marcelo noc si tú sabes o tienes alguna idea donde puedo encontrar o comprar el sensor para cambiarle la parte porque en el mío esta dañado el circuito para el apago del botón de encendido
par
Hola, alguien pudo comprar o cambiar el famoso sensor ribbon que comentó Marcelino? ... Saludos.
par
can not turn off speaker, as soon as I connect it turns on and Does not let me turn it off
Indice 0
1 commentaire:
Sameeeeeee when I connect my the HK aura studio it doesn’t let me turn it back off or connect to it with any device, does anyone know how to fix that or where can I take it to fix it????
par
Where do you find the strip panel?
Indice 0
I could find the sensor ribbon in this website.
Assy touch board Harman Kardon AURA et AURA PLUS (mysav.eu)
Does anyone knows if this is the right one for Aura 2 ?
Indice 0
Ajouter une réponse
Maleen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 45
Total : 5,448
