Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le LG X Power est un smartphone 4G LTE sorti en août 2016. Ce modèle dispose d'une mémoire de 16 Go et utilise le système d'exploitation Android.
battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Répondu ! Afficher la réponse J'ai le même problème
Indice 12
13 commentaires
My lg q6 alpha is showing the red question sign on the screen I don't what to do
par
What do I need too do if my phone want come on and only show a ? Mark
par
my lg is not turning on
par
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
par
I have the same problem in my lg v10 question mark after connecting the charger
par
Voir 8 commentaires en plus
Ajouter un commentaire
2 Réponses
Solution retenue
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
  1. Clean charge port. And cable connection
  2. Replace charger/cable
  3. Replace battery/charge port
Indice 6
5 commentaires:
OK thank you
par
Hold finger on Questiomark for while..
par
still not working..... im getting mad
par
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
par
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
par
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
Indice 2
2 commentaires:
If you get anew battery note to remove the stick on the 4 battery connectors
par
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
par
Ajouter une réponse
Jonathan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 26
30 derniers jours : 122
Total : 58,566
