Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Canon EOS Rebel T3 est une suite à la gamme d'appareils photo reflex numériques d'entrée de gamme de Canon, la série Rebel. Également connu sous le nom d'EOS 1100D et d'EOS Kiss X50, il est doté d'un capteur photographique de 12,2 MP et d'un processeur d'image DIGIC 4.
How to fix error 30
An error 30 occured in my Canon D1100 EOS.. what shouild i do to fix this.. am even getting worse. help the one who knows the solution
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@davie77 Err 30 seems to be vry common problem with this model
Description: A malfunction with the shutter has been detected.
Resolution: Turn the power off, then remove and re-install the battery. Then turn the power on again.
Other than that it sounds like a either a stuck or failed shutter. You could call Canon support for your place of residence and see if this is still covered under a “recall” that was happening a while back.
Indice 3
Error30 on Canon 1100SD> in fact the SD card reader has its oxidized contacts> I used contact spray for electronics with a little brush on the contacts of the SD card> I put the card back in the reader / removed and put it back several times / I leave to act overnight AND now no more errors30 ;-) —from a french guy
Indice 0
Ajouter une réponse
Davie ogallo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 2,633
