Aller au contenu principal
iFixit utilise des cookies pour améliorer la fonctionnalité du site, analyser le trafic et personnaliser les publicités. En utilisant notre site, vous acceptez notre utilisation des cookies et notre politique de confidentialité.
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
20 questions Voir tout
Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
par
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Remplacement de la brosse à rouleau Shark Navigator
par
Ajouter un commentaire
4 Réponses
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
Indice 0
2 commentaires:
That instruction is basically clean it, it doesn't have an answer.
par
Mine just doesn't work no .atter what I do
par
have check all obvious problems but brush roll wont turn
Indice 0
2 commentaires:
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
par
Mine won't even turn manually.
par
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
Indice 0
1 commentaire:
Take it back, why worry?
par
It is either:
A stuck brush because of debris
A bad or broken belt
A bad switch or connector
A bad brush motor.
Indice 0
Ajouter une réponse
Barbara Glosson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 91
Total : 5,545
