Aller au contenu principal
Repair information and support for walk-behind lawn mowers made by the Toro Company.
Spitting Oil out Exhuast when starting
Went to start my mower today and when I pull the chord to start it, it just knocks and a puff of white smoke comes out. I also realized that there is oil, a good amount, dripping out of the exhuast. It's been sitting right side up, never turned over, so I'm at loss for what to do. Any info anyone has would be great.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
I would say you flipped it and that’s why you’re getting that but it could be a gasket try checking the gas for oil
Indice 0
1 commentaire:
Its sat for the winter and I haven't touched it. There isn't oil in the gas. I just put gas in it for the first time this spring. Didnt want gas sitting in it while not being used.
par
Most likely is that you are overfilling the oil. Second would be leaking piston rings.
Indice 0
2 commentaires:
I haven't put oil in it this year since the spring has just started. I checked it and it's at normal level. How would I check the piston rings?
par
Of course the piston rings are around the pistons and the the engine would have to be torn down to inspect them. This usually does not happen until a mower is several years old.
par
Ajouter une réponse
Clif sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 341
