Aller au contenu principal
Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
Questions au sujet de 17 Voir tout
I have a 2003 Toyota Camry v6 that won't start.
It used to die on me ever so often so I replaced the battery. Drove good for a bit and the same thing started happening. If I jumped the car it would start right up until the other day. I've now changed the starter and the entire ignition switch, ignition housing and ignition but it just clicks.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Did you find the problem. I have the same car with same problem. Please let me know
misselle512@gmail.com
par
Ajouter un commentaire
1 Réponse
Solution retenue
Have you checked the see if the alternator is charging. If you put in a new battery and it runs for a few days and the same thing happens again it sounds like the alternator is not charging. You should learn to find out what is wrong before you just start throwing parts at it. You could probably had it repaired for less money if you had taken it to a shop and had them do it or had them at least find out what is wrong with it before they spent at least a couple hundred dollars.
Indice 0
Ajouter une réponse
Llbriggs04 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 258
