Aller au contenu principal
Commercialisée en novembre 2020, la console PS5 présente des graphismes hautement évolués et une nouvelle manette Dualsense innovante. Ce nouveau thème spatial noir et blanc témoigne d'un changement notable par rapport aux anciens designs de PlayStation.
20 questions Voir tout
DualSense Ribbon-Cable: Can I replace it?
Hello guys,
unfortunately i need to replace one of the ribbon-cables in the Dualsense-Controller. Its the one that connects the Vibration motors wirh the mainboard. Any Idea if i can use a different one? Or is this some special Sony thing?
Thanks in advance!
Best Regards
Andreas
Répondre à cette question J'ai le même problème
Indice 5
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I had to replace mine too, I was able to use a 16-pin 0.5mm ribbon cable (this would be 8.5mm wide) that was from an old laptop display until i could get a new one. You will need to be careful though, I tried some I ordered online and it didn’t even power on. I think the laptop one worked because it’s a directional cable and specified which end should go to the motherboard and monitor (or in this case the trigger assembly).
Edit: For the ribbon cable I ordered I believe it was A type, but I think B type would be more likely to work.
Indice 1
2 commentaires:
I ripped my L2/L1 Ribbon cable on my ps5 controller during disassembly. anyway i can buy a new cable and what size is it? Or is it repairable. the cable is sheared in half.
par
If you search for a 16-pin 0.5mm B type cable on amazon or newegg it should come up. Here is one you can try: https://www.amazon.com/dp/B07S1BNYTS/ref...
I haven't tested this one but if it can be used to carry a laptop display it should work for the trigger assembly. You may have to fold it a bit to fit in the controller. If it doesn't work i'd suggest looking for a cable with higher tolerances (i.e. max voltage, ampage, etc.), b-type, and 16 pins at 8.5mm wide.
par
Yeah those are extremly hard do find, Found a guy in Germany selling them
Indice 1
Hi Andreas , I had the same problem, then I found these guys in the Netherlands.
https://xqgaming.com/en/563-repair-parts
Indice 1
3 commentaires:
recently I got some from these guys in China. I got them in 10 days.
https://www.aliexpress.com/item/10050030...
par
Does this company have a good reputation? Do they sell a ribbon cable for the PS5 controller touchpad? I have tried to find one on Amazon but am unsure which one is correct.
par
Since Andreas's post in 2020 these parts are more widely available now; and you can find them now on eBay and Amazon.
par
Ajouter une réponse
Ace100ace200 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 85
Total : 5,259
